Fuse slot 12, HST Calibration
   / Fuse slot 12, HST Calibration #1
adegiulio
Red Hook NY
JD 4310
I was looking at my fusebox and noticed a fuse was sitting askew. I pulled it out just to check it, and when I put it back, I mistakenly put it in fuse slot 12. After starting the tractor back up it wouldn't move. I noticed what I did wrong and switched the fuse back to its original stop, but now the tractor still wont move. The sticker on the fuse box explicitly says not to put a fuse in slot 12, which makes me think its used by a diagnostic tool or something.
So, does anyone know how to recalibrate or clear this condition that I've created? I have a rented power rake in the back of my truck that needs to be lifted out (and used while rented) so time is a bit of the essence here.
Thank you for any input.
Anthony
   / Fuse slot 12, HST Calibration #2
HST ??
What model Deere do you have?
HST= Hydrostatic Transmission. It's a 4310.
   / Fuse slot 12, HST Calibration #4
When the calibration fuse is installed, it erases the original calibration parameters from the controller. A new calibration must be performed to reset those parameters. If any of the sensors or potentiometers are out of adjustment, the calibration will fail. They will need adjustment before calibration will be successful. This is best performed by dealer that has the proper tools and info to repair.
Yeah, I found a thread online from someone who did it without the equipment. I sent them a PM, hoping they will get back to me. So frustrating since I have so much work to do..
   / Fuse slot 12, HST Calibration #6
Did you get it to finally calibrate?
It's in the shop :(
Turns out that potentiometer was bad. New one should be in today. Hopefully it gets finished this afternoon...
Thanks again for all your help.
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
30007 (A53424)
30007 (A53424)
KMC 5610 LOT NUMBER 33 (A53084)
KMC 5610 LOT...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
