Fuse cover door on JD 4300
   / Fuse cover door on JD 4300 #1
Bob_Trevithick
Platinum Member
Williamson, NY (near Rochester)
JD 4300 MFWD
This seems so silly, but I simply cannot get the fuse cover door to close and latch shut on my new 4300. The dealer said if all else fails to come in and try a few on their lot, see if I can spot what's different with mine. Of course I'll do that the next time they are open.
I popped it open just out of curiosity, which turned out to be an okay thing because a few of the fuses needed to be seated better. But it simply will not latch shut now.
I know, it's a very minor problem.. but still.. it would be nicer if the door wasn't flapping around while I work.
When I try to close it, there is clearly a pressure point in the middle, because neither side sits flush. It seems obvious that the latch pin goes through the hole, and then moves downward to lock it shut. But it simply never gets shut far enough for this mechanism to work.
Any suggestions welcome!
TIA, and Happy Holidays to all,
Bob
Bob Trevithick
   / Fuse cover door on JD 4300 #2
Duct Tape till after the Holidays.
Have A Merry Xmas
Egon
   / Fuse cover door on JD 4300 #3
<font color=red>...Duct Tape...</font color=red>
Spoken like a true Farmer...! /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
   / Fuse cover door on JD 4300 #4
John, the first time my brother asked me if I had any "hundred mile an hour tape", I didn't know what he was talking about. He'd been flying fabric skinned airplanes in Alaska and I found that was what they called duct tape.
<font color=blue>...Duct Tape till after the Holidays.</font color=blue>
ROFL!!!! /w3tcompact/icons/smile.gif I knew there was something essential missing from my tool kit. Duct tape! Yes!
<font color=blue>Have A Merry Xmas</font color=blue>
You too, Egon!
Bob Trevithick
   / Fuse cover door on JD 4300 #6
Is the lever "A" in the proper position...? {lower to close}
<font color=blue>...Is the lever "A" in the proper position...? {lower to close}</font color=blue>
Yep. When you close your door, does it close completely? Mine acts like it isn't lining up right. It's hits a high spot in the middle, which I presume is the catch mechanism, and both sides stick out quite a ways. No matter how much force is applied to it, it just won't go in. I make sure the pin goes into the hole, then push hard and move the lever down to lock it. No dice. Duct tape for now!
Thanks, John.
Bob
p.s. It occured to me that maybe I should replace the lock with a real lock.. so I can take out the starter fuse and then lock the panel shut with a key. Minimal security, I know, but anything that slows them down a bit.. And at least my locking setup should stay closed. /w3tcompact/icons/smile.gif
Bob Trevithick
   / Fuse cover door on JD 4300 #8
Bob,
<font color=blue>take out the starter fuse </font color=blue>
You could replace the starter fuse with one which was blown, not to obvious, but you would have to remove the duct tape every time you wanted to use the tractor/w3tcompact/icons/smile.gif
Al
   / Fuse cover door on JD 4300 #9
<font color=blue>...It's hits a high spot in the middle...</font color=blue>
Bob,
I'll bet it's something, you'll end up kicking yourself over... /w3tcompact/icons/wink.gif
By chance, do you have the fuse door upside down or reversed, wrong position...? Think, something logical, something obvious, and something simple... {I can't see it...you can...!}
How you tried a bigger hammer......? JUST KIDDING Bob! /w3tcompact/icons/smile.gif
<font color=blue>...You could replace the starter fuse with one which was blown, not to obvious, but you would have to remove the duct tape every time you wanted to use the tractor</font color=blue>
As long as none of that pretty <font color=green>green</font color=green> paint comes off with the duct tape, I could live with that. /w3tcompact/icons/smile.gif
Bob Trevithick
2000 GAL FUEL TANK (A52472)
2000 GAL FUEL TANK...
2024 JOHN DEERE 461M LOT NUMBER 60 (A53084)
2024 JOHN DEERE...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2013 FREIGHTLINER CASCADIA SLEEPER (A52576)
2013 FREIGHTLINER...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
