Fuse block replacement on YM 1700, perhaps others
   / Fuse block replacement on YM 1700, perhaps others #1
rinms
Yanmar 1700
Just to past it along, Bussmann makes a pretty much "bolt-on" replacement for the "wire fuse" fuse block of the Yanmar YM 1700 I have. It is available from, at least, Advance Auto Parts (in the US) in my area. The part number is 15600-06-20. Even the mounting holes are in the right place. It is a six-circuit block, so if you need additional circuits, two are available (we used one for a 12v "power port"/cigarette lighter adapter).
On our tractor, it was simply a matter of replacing the ring terminals with female spade lugs and plugging them up.
Some tips:
1. Disconnect the battery - seriously, this isn't just some legal, CYA safety stuff - you'll be fooling with the wiring, for gosh sakes!
2. On our tractor, the original fuse block was held in place with two bolts and nuts. The nuts are inaccessible without removing the fuel tank. Remove it and save the nuts. They are common to other things on the tractor, plus, you'll probably want to remove it anyway to install the new block. It's pretty easy, simply loosen the forward retaining strap bolts/tensioners.
3. Replace the original rings terminals with appropriate female spade lugs.
4. Mount the new block in the original holes with 1/4" x 1 1/4" bolts and nuts, installing the _heads_ of the bolts from the fuel tank side to prevent the slightly longer bolts from wearing a hole in the tank. Secure the nuts from the fuse block side.
5. Plug the wires up and add fuses. Obviously, stick pretty close to the rating of the original "wire" fuse.
I have no idea if this block will work on all 1700s or other models. I can say it was a snap on one particular 1700.
If you have _any_ wrench-turning and electrical skills, it is about a 15-20 minute job and you can then use standard ATO fuses (the medium-sized auto fuses, the little ones are "minis" and the bigs ones are "maxis"). If you have no such skills, you may not wish to attempt this.
Hope this helps.
   / Fuse block replacement on YM 1700, perhaps others #3
One of the very first thing I did to my 1700 was to replace and re-wire the fuse Box, and repositioned it so that I can get to the fuses much easier,:thumbsup:
Galvanized Livestock Gates - (5x Gates) (A55218)
Galvanized...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
1982 LeeBoy Motor Grader (A55218)
1982 LeeBoy Motor...
City of Lakeland (A51691)
City of Lakeland...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55302)
PENDING SELLER...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
