Fuse block question
   / Fuse block question #1
donnyviking
rochester mn
MF 451 FWD
I have been chasing down an electrical issue on MF 451 to primary pump. I found on odd issue, plus have a few questions for smart electrical people.
1. The manual electronic schematic shows wire from ignition switch to fuse block 4. Continuity check shows 2 ohms resistance. The fuse is labeled as "spare" at the fuse box. Why would it say that?
2. There is only one wire going to fuse 4, and also only one wire going to several other fuses. It has 12 volts going fuse. Where is the output?
3. The coup de grais -- there is only a metal receptical on one side of fuse block 4, so when you insert the fuse one side contacts metal and the other side is touching air. I assume this is the break in the circuit???
I'm still trying to figure out how to remove the fuse block from the holder. There are clips on the fuse blocks but I'm not sure if block is pushed down thru the holder or pulled up.
Let me know your thoughts.
   / Fuse block question #2
many blocks have spare circuits that you then use a tap fuse to get power from that line.
Thanks Soundguy. That makes sense. I'm trying to research how the fuse block itself functions.
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
TROY BILT PRESSURE WASHER (A51248)
TROY BILT PRESSURE...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
UNUSED AGT SAWMILL MODEL - YC32G (A51248)
UNUSED AGT SAWMILL...
