jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 21,008
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
I was rotary cutter mowing last Monday for most of the afternoon. As I was almost finished, my wife came driving up on our Kawasaki Mule to bring me some cool water. I shut off the tractor and had a drink before attempting to restart, but the infamous PTO lamp was on with the PTO disengaged and I knew exactly what that meant. Since it was fairly late in the day and the tractor was just in a good place, I left it for the night and returned to my house with my wife.
Since we were having a 4th of July party on Wednesday, I just left the tractor sitting until yesterday, when I had time to return with fuses in hand. After two new 10 amp fuses popped on attempting to start the tractor, I knew this was going to be more than the average problem. I had to go somewhere yesterday afternoon, so it was today before I could return.
With my electrical schematic, VOM, and jumpers in hand, I returned this morning, determined to get the tractor going. What I found was that the fuse would not blow if I unplugged the fuel cutoff solenoid. I made a couple of inline ammeter readings and found that the solenoid would sometimes pull more current than at other times. It seemed like it was erratic. I cycled it on and off with a jumper about a dozen times and then replaced the fuse and put the wiring back to normal. The tractor fired right off and after several trys, would not blow the fuse again.
In my opinion, this problem now appears to be associated with the fuel cutoff solenoid. I think I'll increase the size of fuse #2 to 12 or 15 amps and see if that doesn't cure the problem. I just think that the solenoid sometimes drags a little and pulls enough extra current to blow the fuse. That's what my meter reading showed as it sometime indicated around 7 amps and at other times around 10 amps. The rest of the load was only 0.39 amps altogether, so I'm pretty sure the solenoid is the culprit for this problem rather than a "relay race" as I previously thought.
