Full-Range Throttle Mower Engine
/ Full-Range Throttle Mower Engine #1
Rip
Platinum Member
NW Tasmania, Australia
Kubota F-2880 & F-3680
Not exactly tractor related, but some here would likely be able to help:
I am looking for a new Honda or B&S 5.5 to 6.5 Hp (160-190cc) V-shaft mower engine for a power cart project (DR PowerWagonPro clone) that must have full-range throttle ability, not just full-speed or off. Hard to determine carb/governor set-up from most mfg lit. Want something this way out of the box not have to change or modify carb or gov.
Actual model Suggestions?? Happier New Year!! Rip
/ Full-Range Throttle Mower Engine #2
Most small engine (today) have friction throttle lever (governor) for constant speed, its pretty easy to disable and to be able to run throttle butterfly as variable..... Don't see any problem other than getting linkage to work like you want it....
Dale
That is how all used to be, but most today, including replacement engines of any brand, are Fixed-Speed .... a quick start and off-to-the-races at full throttle....some may be changeable, but many do not even have a proper throttle. With further research I have found some that still have full-range throttle, so should be good.
Bobcat 435 FastTrack (A60462)
Bobcat 435...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
Auger Drill Bit Skid Steer Attachment (A61572)
Auger Drill Bit...
2011 Cadillac Escalade 4x4 Ext. Cab Pickup Truck (A61573)
2011 Cadillac...
