Oil & Fuel fuel
/ fuel #1
cabin kioti
Sullivan County Pennsylvania
ck 30 hst
I have about 25 gallons of kerosene left over from winter and I was wondering if I could use it in my ck30 if it was diluted with off road diesel fuel.What I don't know is the persentage to use per gallon of diesel.I have some friends that have bigger equipment and they use up to 50 percent in the winter. I would like some oppions. Thank's all
/ fuel #2
Sell it to your friends. I wouldn't dare use it in the CK30 unless the manual allowed for it in the dead of the cold winter.
Hi,
During the winter months Kioti allows for a 20% mixture of Kero to help keep fuel from gelling. The Kero does not lubricate as well as the regular diesel.
If I were going to use it I would go with a 10% mix and add a little howe's lubricant. You should be OK with that formula. (That is 10% Kero to 90% diesel) I'm sure you knew that, but you can't be too careful.
KiotiDave
KiotiDave said:
Hi,
KiotiDave
I have a gallon of Kero I'm gonna add to my 30 gallon or the 55 gallon drum.
2023 CATERPILLAR 259D3 SKID STEER (A64279)
2023 CATERPILLAR...
7 Barrel Masport Vac Pump (A62679)
7 Barrel Masport...
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
Kubota Industrial Turbo Diesel Engine - Tag Missing - Pump Takeout - Approx. 80-85 HP Class (A63689)
Kubota Industrial...
(3) Tires (A65640)
(3) Tires (A65640)
