Oil & Fuel fuel
   / fuel #1
cabin kioti
Bronze Member
Sullivan County Pennsylvania
ck 30 hst
I have about 25 gallons of kerosene left over from winter and I was wondering if I could use it in my ck30 if it was diluted with off road diesel fuel.What I don't know is the persentage to use per gallon of diesel.I have some friends that have bigger equipment and they use up to 50 percent in the winter. I would like some oppions. Thank's all
   / fuel #2
Sell it to your friends. I wouldn't dare use it in the CK30 unless the manual allowed for it in the dead of the cold winter.
   / fuel #3
Hi,
During the winter months Kioti allows for a 20% mixture of Kero to help keep fuel from gelling. The Kero does not lubricate as well as the regular diesel.
If I were going to use it I would go with a 10% mix and add a little howe's lubricant. You should be OK with that formula. (That is 10% Kero to 90% diesel) I'm sure you knew that, but you can't be too careful.
KiotiDave
   / fuel #4
KiotiDave said:
Hi,
KiotiDave
I have a gallon of Kero I'm gonna add to my 30 gallon or the 55 gallon drum.
2008 Ford F-250 (A52748)
2008 Ford F-250...
2024 Spartan KGZ-XD Zero Turn Mower (A50514)
2024 Spartan...
2019 Ford Fusion SEL Sedan (A50324)
2019 Ford Fusion...
2014 Jeep Cherokee Latitude SUV (A50324)
2014 Jeep Cherokee...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2015 Make...
