Fuel wood dilema
   / Fuel wood dilema #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I've got myself into a situation over home heating fuel wood.
I've got a years worth of 2-3 year cut split stacked and covered.
Naybe more.
Then I cut a couple more good sized hardwoods earlier this year, and have 3-4 months of heat in a few stacks around the property. (I won;t get into the hemlock ;-)
Now I've had a 8 cord log load delivered and stacked out front on crib logs.
The dilema
There is really NO good place to stack split wood from those new logs that would mean loading in a small trailer and driving somewhere. The log pile IS the place I like to stack, but the fringe area is already full.
Question is.......
Do I start in cutting rounds now, while the logs are still green, and stack the rounds near to where they fall,
or
Do I wait till late winter and spring to cut split and stack the new wood into the spaces vacated by the winter burn.
Cutting "dry" logs vs cutting fresh wood.... ?
decisions///decisions"
Conversation////
   / Fuel wood dilema #2
I’d at least block them up to let them start to dry/limit decay
Splitting is still easier when frost gets into them
   / Fuel wood dilema #3
I’d probably just leave them as logs and cut and split them after you’ve burned some. No scientific reason it’s just what I’d do.
   / Fuel wood dilema #4
I would also leave them as logs and get them elevated off the ground.
   / Fuel wood dilema #6
Do not buck them as they will dry, and than it will be impossible to split, unless you are using a hydraulic splitter. Also if you buck them and they sit around they will be more exposed(more surface area to air, more water) and will rot faster. Just put the logs on skids if you can till your ready.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
