Fuel Usage
   / Fuel Usage #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
My Toolcat is thirsty for fuel ALL THE TIME.
I seem to go thru at least a gallon per hour even while taking it very easy. The fuel tank is not too big so I am refueling quite often.
Are others experiencing something similar?
Thanks
Yooper Dave
   / Fuel Usage #2
<font color="blue">( I seem to go thru at least a gallon per hour even while taking it very easy. ) </font>
That sounds pretty good to me. My tractor uses 3 gallons/hour and I think my 873 SSL probably uses close to the same.
   / Fuel Usage #3
Yooper Dave,
I use just a bit over a gallon per hour, but don't notice as much since my Toolcat 5600 Turbo has a larger fuel tank capacity than your non-turbo Toolcat (16 gals vs. about 10 gals) /forums/images/graemlins/cool.gif. Also, perhaps turbocharger system on my 56-hp Toolcat helps keep thirst at bay no matter how heavy or light you run throttle or work the machine.
Are you moving a lot of snow with your Toolcat? What attachments have you gotten so far?
   / Fuel Usage
Hi Brian,
I moved quite a bit of very heavy snow earlier with the 7.5' BOSS snow blade. It has warmed up quite a bit, so I have been loading manure with the material bucket.
I just bought a 66" brush grapple bucket which I still need to put the flat faced hydraulic connectors on in the spring.
Yooper Dave
   / Fuel Usage #6
Our Tolcats burn approx. 1 gallon an hour. During snow removal operations we are operating at full throttle and traverse over 185 miles of residential streets doing contracts and "one shots". Full throttle and 2nd speed saves quite a bit of time.
Timm9
   / Fuel Usage #7
I would love to see pictures of the mount and the toolcat with BOSS blade! Maybe they have already been posted in another thread?
   / Fuel Usage
Here is one
Yooper Dave
   / Fuel Usage
Here is another one
Yooper Dave
   / Fuel Usage
Here is yet another one
Yooper Dave
2018 Ford Fiesta SE Sedan (A48082)
2018 Ford Fiesta...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2013 MAGNUM TRAILER GENERATOR TRAILER (A50854)
2013 MAGNUM...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
