Fuel tank woes
   / Fuel tank woes #11
I can’t understand why your current tank cannot be cleaned. Did they use a light acid like vinegar? Did the fill it with nuts and bolts and then tumble? A slosh coat should encapsulate anything that remains. To me, the only reason to replace a tank is if it is leaking and can not be repaired.
   / Fuel tank woes #13
we used to put a piece of chain in the tank and spend some time shaking it around. when its as clean as possible took it to a radiator shop to have it boiled out. then after flushing it with clean hot water and fully dried put a can of tank sealer in it.
   / Fuel tank woes #14
I have cleaned a few gas tanks and found that after getting it as clean and dry as I could dumping in about a quart of WD 40 and sloshing it around real good was good insurance against any residual moisture. For the younger group here, WD 40 was developed during WWII as a water displacement formula for equipment being shipped over seas.
There were several companies competing for the govt. contract but a company in San Diego,Ca. came up with WD 40 and won the contract.
   / Fuel tank woes #15
I'd take it to a radiator repair shop and have it boiled out. Then some tank sealer. Just like Rebeldad1 said.
   / Fuel tank woes #16
I dont understand where all the debris is coming from? Is the tank so rusted and rotten that it is still flaking off chunks inside? Or is there a problem with the fuel going bad, or is there moisture or bugs and dirt getting into the tank?
   / Fuel tank woes #17
Fuel tanks are quite susceptible to condensation. Any enclosed space vented to atmosphere accumulates condensation.
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
Wooden Rack Hay Wagon (A50775)
Wooden Rack Hay...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
King Kutter TG72 Rotary Tiller Tractor Attachment (A55851)
King Kutter TG72...
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
