Fuel tank woes- Ford 1920
   / Fuel tank woes- Ford 1920 #1
Wasmeneh
Well my 1920 has let me down, inside of the fuel tank is very rusty. I've emptied it out several times and got lots of rust out but there seems to be an unlimited amount.
There are no new tranks available for this model but I have a used one on the way. The question I have is to coat or not to coat it. Some say POR 15 works great others say it can peal off causing other problems. If the "new" tank is clean should I just clean it and use it or should I coat it.
Thanks in advance
Mike in NC
   / Fuel tank woes- Ford 1920 #2
If the new tank is clean I would just use it, But keep it full of fuel.....:2cents:
That's what I'm leaning toward.
   / Fuel tank woes- Ford 1920 #4
Thanks in advance
Mike in NC
Has your 1920 with rusty tank, spent most of it's life outside?
Well must have, I bought it used so that must have been the case. It now live in a containor so hopefully after I straighten this out I'll have no more issues.
   / Fuel tank woes- Ford 1920 #6
Hello, your job is really hard, I hope you find the warehouse you are looking for.
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
2014 Volvo Sleeper Tractor Truck (A52384)
2014 Volvo Sleeper...
2016 Bad Boy 54in. ZT Elite Zero-Turn Lawn Mower (A53117)
2016 Bad Boy 54in...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2018 Bobcat E50 (A50123)
2018 Bobcat E50...
