Oil & Fuel Fuel tank vacuum
   / Fuel tank vacuum #1
jbitting
Clover, SC
YM1500
I have a YM1500. Plastic fuel tank, fuel line out the bottom. There is another (small) line going into the tank by the cap. I thought it was a vent until I saw it was coming from the injectors... what is this little line for?... meanwhile, my fuel tank is pulling a vacuum and trying to crush itself.
1. should the small line be coming from the injectors and what is it?
2. how do I get around the tank vacuum?
I'm sure one of the Yanmar vets has seen this before.
any help appreciated.
Thanks,
Jake
   / Fuel tank vacuum #2
Maybe it's the supply line for the thermostart reservoir.
   / Fuel tank vacuum #3
I believe he is speaking of what the manual calls a bleed off line, that runs from the injectors to the tank.
   / Fuel tank vacuum #4
The line is for unused fuel returned to the tank. I had a YM1401 do the same thing with the tank. I had put the wrong cap on it. The cap must have a vent. I had actually put a new gasket on the cap and it was too soft and closed the vent notch in the cap threads.
   / Fuel tank vacuum #5
Jake,
My YM1700 did that a few times if I tightened the cap too tight. If I put it on enough to not vibrate loose, all was well with the tank.
Hope this helps
   / Fuel tank vacuum
Roger that fellas...
Thanks for the replies...
will check the cap/gasket and make sure all is well with the vent notch.
I have been known to overtighten a cap now and then too <grin>
appreciate the replies.
Thnx much,
Jake
   / Fuel tank vacuum #7
if you check and can't find vent run engine with fuel cap slightly loose the pumps on the engine draws a vacum just like old fuel pumps on gas so if tank ain't vented it will pull vacum on it's self..
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2018 Dodge Charger Sedan (A51694)
2018 Dodge Charger...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
Hydraulic 80mm Quick Coupler (A52384)
Hydraulic 80mm...
JOHN DEERE 1705/6700 (A53084)
JOHN DEERE...
