Fuel tank vacuum stalling Iseki Landhope
   / Fuel tank vacuum stalling Iseki Landhope #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
First post here.
I have newly purchased my second Iseki, a TU200 Landhope. 3 cylinder. My first is a G192. I was impressed with the reliability of the old girl. Looked until I found one with 4wd and a front end loader.
I was using my "new" one yesterday and after an hour of running it chugged to a stop. I investigated and found that the fuel tank had a big vacuum on it. I guess I could vent the tank with a fitting but presume that that has been done by the manufacturer. Is there a vent line that needs to be cleaned? I was able to get it going and noted that after every 20 minutes it had redeveloped the vacuum. However I didn't have another stall out.
Thanks for any help.
   / Fuel tank vacuum stalling Iseki Landhope #2
Is there a vent built in to the cap ?, maybe it's plugged.
   / Fuel tank vacuum stalling Iseki Landhope #3
It may be the wrong cap. My TA210 cap is loose fitting. It has a hard paper type gasket.
Yes it was an aftermarket cap.
Stamped Eaton on the inside. I took out the rubber seal and notched it at the tiny vent hole. Thanks for the help guys.
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A51691)
2019 Caterpillar...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
UNUSED FUTURE ELECTRIC MASSAGE CHAIR (A51248)
UNUSED FUTURE...
