Fuel Tank Mitsubishi D2050 Tractor
   / Fuel Tank Mitsubishi D2050 Tractor #1
EWhite
I need fuel tank for Mitsubishi D2050 tractor.
   / Fuel Tank Mitsubishi D2050 Tractor #2
Why? Missing one entirely or leaking? Leaks can usually be fixed with products like creem.
The tank has alot of rust in bottom and leaking at seam. Where do you get the product creem?
   / Fuel Tank Mitsubishi D2050 Tractor #4
Most auto parts stores. Motorcycle shops also carry it. Eastwood also has a good tank sealing product.
I would take the tank off, remove the sender, drain, cap, etc and pressure wash it. Some of the old timers swear that strapping a tank to a rear tractor tire, putting a couple pounds of old nuts/bolts in it and driving for 20-30 min cleans up the inside rust. Probably does.
Then use a good tank sealer. One caution, The tank inside needs to be oil, grease, fuel free. I would buy a gal of acetone and after cleaning slosh that around in the tank. Then spray a couple cans of brake cleaner in it. Then use the procedure in the seal kit.
Oh, some better radiator shops will seal tanks too. Cost is about $100 over the kit price on average. Usually a good deal if you can find them around your house.
Thanks for the info., has been helpful.
ABI TR3 LOT IDENTIFIER 134 (A53084)
ABI TR3 LOT...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2019 JOHN DEERE XUV835M LOT IDENTIFIER 26 (A53084)
2019 JOHN DEERE...
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
