Fuel Tank fill filter
   / Fuel Tank fill filter #1
7000
San Diego,Ca
Looking
Hello Guys,
Just took delivery of my new LS XR4046H tractor. It came with an empty fuel tank. Had to go downtown and bring back new diesel fuel cans to fill it. I have no trailer for the tractor.
Upon filling the tank I managed to poke the fuel strainer at the entrance of the tank with the spout of the fuel can. It had one of those push pin activators on it. The pressure ridge was too short to hold with the push pressure and the entire spout shot into the fuel tank of the tractor. In process the long filter at the top of the tank entrance was shoved into the tank.
I don't think that will hurt the tractor fuel pump or anything but there is that thing now bouncing around inside the tank. Whenever I fuel up I just have to put screening in the fuel can or another screen at the top of the tank I guess.
My solution to get the thing out of the tank is to run the fuel low and then try to fish it out with a coat hanger. It is not metallic so I cannot use a mag pickup. I cannot see it in the tank so I am wondering if my poking around inside the tank trying to hook it out will damage anything. Just leaving it in should be okay I think. But, just can't stand the idea that it is in there.
Any suggestions?
Thanks.
   / Fuel Tank fill filter #2
If you have access to the fuel gauge sending unit, remove that and fish out the strainer. The sending unit hole is much larger than the filler pipe. One of those little three prong picker upper gadgets would be my choice but you will have to get a long one to reach the bottom of the tank.
   / Fuel Tank fill filter #3
I always remove that strainer when I fill my LS tractor because it wont flow as fast as my pump pumps. I don't know why I don't just throw it away as I filter my fuel thru a 10 micron filter when it is pumped in. My Kubota doesn't have a fuel neck strainer. I really don't see any need for that if you keep your fuel clean. I don't know if it would trap water on not, but the fuel filters do so it really isn't needed.
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55218)
2015 Ford F550...
2009 Ford F-350 4x4 Flatbed Truck (A51692)
2009 Ford F-350...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
