TonyC
Platinum Member
A bit ago I started a discussion about putting a fuel drain in the bottom of fuel reservoir to drain the water out of it periodically. I'm still trying to get someone to weld a nut on the bottom of my tank in order to screw in a petcock. Those that can weld aluminum evidently don't wish to fool with such a minor task. I've about given up.
Now for Plan B…here's my thoughts. I fix a nut on the bottom of the tank using JB Weld or something similar. After I'm sure it is well secured, I then drill a small hole in the tank then add the petcock. The obvious problem…150 gallons of diesel fuel dying to leak out on my topsoil. If not this year, maybe next?
So is this a really bad idea? Are there any other suggestions that don't involve welding?
