Fuel System Woes
   / Fuel System Woes #11
So I finally got around to changing the filters on the MF35 with a Perkins. These filters and canisters were horrible, perhaps 15 years old or older!! After cleaning the canister some I discovered why it had a slow leak, I thought it was gasket related. Well it seems the water mix in bottom caused major corrosion and a few pin holes.
This is a CAV filter unit, and some aftermarket systems use a can style filter with a glass bowl under it. Besides finding a good used unit or a new one, how could this be repaired? It appears it was repaired before with silver solder or some such around the drain bolt. I have even thought about jb weld just to try it. I have never silver soldered or brazed anything and could give that a try.
What do yall think? View attachment 675554View attachment 675555View attachment 675556View attachment 675557View attachment 675558
I'd grab the part number search the web for new or used. Click to enlarge:
   / Fuel System Woes #13
I have a buddy that does not believe in maintenance.
His B21 was stuttering, lacked power etc.
Well his air cleaner looked like a bird had nested there and his fuel filter was so dirty that it had collapsed.
Never mind what his radiator screen looked like.
Never learns, just says how good a Kubota is built to withstand abuse.
LOL, treats his cars the same way.
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
2008 VOLVO VNL670 SLEEPER (A51219)
2008 VOLVO VNL670...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
Hayrack (A50515)
Hayrack (A50515)
