fuel supply issue on TC 45D
   / fuel supply issue on TC 45D #1
TimG1981
Saint Charles
new holland tc45d
I have a 2003 New Holland TC45D that I'm having issues with. I have a good supply of fuel when I loosen the bolt on top of the fuel pump to bleed the lines, but I cannot get any fuel to the injectors. I have tried loosening them and cranking when they are loose, but no fuel arrives. Any suggestions?
   / fuel supply issue on TC 45D #2
fuel shut of solenoid stuck inside the injector pump?
   / fuel supply issue on TC 45D #3
Its not uncommon for the shut off solenoid to become inop..
Its located to the left of the injection pump.. it looks like a "red bull" can..
It unscrews from the housing.. normally a big pair of pliers will get it out if it doesn't have a hex head on it..
If taking it out & trying to start the engine doesn't get fuel out of the lines.. then you have injection pump problems..
THE rack is stuck..
SOMETIMES you can free it up by sticking a 90* scribe in the shut off hole & try to move the rack back & forth..
BE GENTLE.. you don't want to break or bend anything..
IF it wont free up.. you have to remove the pump..
Feel free to send me a pr. msg for help.. TPG
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
Ground Breaker X Backhoe BH80X 3 Point Hitch Attachment (A51573)
Ground Breaker X...
JOHN DEERE 8245R LOT NUMBER 232 (A53084)
JOHN DEERE 8245R...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
2006 FORD F-250 (A52472)
2006 FORD F-250...
