Fuel stabilizer
   / Fuel stabilizer #1
Hagalaz14w
Mexifornia
Kubota L3200
I recently got a fuel stabilizer to use in the gas I store for my ATV. On the label it says"for all gasoline engines". I also keep a 5 gallon can of diesel for my Kubota. But diesel isn't gasloline What to use as a stabilizer for diesel?
:newhere:
   / Fuel stabilizer #2
"Stabil" had a stabilizer specifically for diesel fuel. It has a green label instead of the red one for gas.
   / Fuel stabilizer #4
Diesel has other issues that additives address ... like lubricity, cetane boost, anti-gel, algae, water handling etc.
PowerService and Stanadyne are example products that cover the above and more.
   / Fuel stabilizer #5
IF you keep it out of the sun the diesel should keep for about a year as long as the container is closed up tight. If you are in Southern California then you don't have the worry of sub zero temperatures and anit-gel is not needed.
   / Fuel stabilizer #7
I have several diesel machines that see very sporadic use. Sometimes they go a year between being ran. Never did anything special to the fuel and never had any problems.
   / Fuel stabilizer #8
Stabil has a specific product for gasoline and another for diesel. The one for diesel has been hard to find in my area lately so I have gone to Amazon to purchase. I have Amazon Prime so the outrageous shipping for a quart is nill for me. All these additives can get expensive if you use the tractor a lot but considering the cost of tractor repair these days maybe not so expensive after all. Some feel these additives are just snake oil and others feel they are a good insurance policy against poor fuel quality.
   / Fuel stabilizer #9
PRI products (PRI-G for gas, PRI-D for diesel) beat the whiz out of Stabil products. I used to use Stabil, but found after a year, gas 'varnished' even in a seal container. I've stored both gas and diesel for 4-5 years at a time with PRI, and never had an issue.
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
2024 Case International 45C Tractor (RIDE AND DRIVE) (LIKE NEW) (A50774)
2024 Case...
2000 Ditch Witch 3700DD Ride-On Trencher (A50322)
2000 Ditch Witch...
Towable Jump Pack (A50774)
Towable Jump Pack...
