Fuel stabalizer
   / Fuel stabalizer #51
No body asked but as a small engine mechanic for the last 20 years I'll chip in my two cents. This can be an issue that causes friends to end friendships. But here is my experience and reasons. I recommend IF E10 is used to use some type of stabilizer but if the unit is not used for 39 days or more drain the complete fuel system, yes that includes removing the carburetor bowl and emptying it or if it has a drain opening the drain and draining it. After all new equipment is shipped with no fuel in the tank or carburetor.
If you have E10 and don't use it within 30 days pour it in your car or truck and refill your cans and add a stabilizer to the fresh fuel. As for using high test mid grade or regular use what the manufacturer recommends. Remember they built it and have to stand behind the warranty. As for using high test why? There is only two reasons to do so. One it is the recommended fuel and you will have a lighter wallet after you leave the pump. Just a thought about high test also, It is refined for a higher octane, resistance to preignition which means it is harder to light could that make starting harder?
Many don't understand that there are at least two different blends of gasoline. Summer and winter. Summer blend has less volatiles in it so it does not evaporate too fast. Winter blend has more volatiles for those easy starts when it is cold. That is why the snow blower left sit all summer with gas in it will have more problems than a lawn mower left with gas in over the winter.
As for stabilizer don't care what you use I have seen all not work and really "gum up" the carburetor. The most important point is it is not a miracle product and still has a time limit mostly due to how the container was stored and I do not trust the length of storage time on the label!
A lot of fuel related issues are caused by storage conditions. You cannot expect a unsealed container sitting in the sun to keep fuel fresh as one tightly sealed sitting in a dark corner where the temperature rarely changes.
Personally I prefer to use nonethanol gasoline but have had success with E10 also. But honestly I prefer diesel.
So there are my two cents. Give it some thought and do what you want to----You will anyway!!
Have a great day
Many good points made here. I live in Florida and buy gas (E10) for my small engines in 50-gallon quantities. (I hate going to the gas station.) I have treated it forever with Red Stabil and have had extremely few issues in any of my small engines. My chain saws, weed trimmers, blowers, generators, etc all do really well with gas stored for possibly a few months all start well. After Hurricane Michael in October 2018, I was glad to be able to store gas in this manner as we had no power for several weeks and had to rely on generators solely. There was only one place in town you could even get gas after the storm and the lines were horrendous while waiting for gas. Hence another reason to buy and store in bulk when you can. One thing I find with 2 cycle engines is using Stabil in the gas and a quality 2 cycle oil seems to make difference. Over the years I have come to use Husqvarna 2 cycle equipment. I started using their 2 cycle oil as well and haven't had any start or run issues since. I have also noticed that I stopped fouling spark plugs while doing this. Plugs seem to last for years now and the engines run cleaner. The last thing I'd like to mention is that my stored equipment doesn't sit for months at a time without running. I have gotten in the practice of starting all my engines around the beginning of each month and let them run for 5- 10 minutes, then put them back. (Kind of make a practice of it like paying rent or mortgages.)The only issue I have had since doing this is the fuel lines on 2 cycle engines still rotting out. Don't think there's any cure for that. Just my experience and 2 cents worth. Thanks for reading.
   / Fuel stabalizer #52
You do know those high performance 2-stokes need high octane?
   / Fuel stabalizer #53
On small engines that get left for some time I use a local made stabiliser that also cleans and takes care of moisture and fungus, a lot of small engines can get gummed up real easy, so they need something if not always being used.
The ethanol is not the issue.
   / Fuel stabalizer #54
You can drain the alcohol off. I have been running ethanol in the same mower for 20 years. Run it in my old carb truck too. But, I use the mower year round. Nothing around here has a park it season. Winter comes, off with the deck, on with the trailer.
   / Fuel stabalizer #56
Basically I don't do anything. I use the low grade pump gas in everything and never have a problem. Lots of stuff sits over winter and never fails to fire up in the spring....Don't use any additives in anything.
   / Fuel stabalizer #57
I agree, but what about if you’re out in the field with say, the log splitter? Do you use a generator? Then you only have 1 small engine to maintain?
Right. I try for machines that run on my pto first, then the generator/welder that I maintain. I can’t get away from all small engines, the goal is to minimize the numbers...
   / Fuel stabalizer #58
Im tired of having problems with small engine carbs and I plan to do something about it.
In my area finding ethanol free gas isnt easy and from what I have read dosent necessarily solve the problem.
I know that running the fuel tank empty at the end of the season isnt the answer either because Ive seen first hand the powdery white residue left behind after things dry out.
What do you guys do to not have any problems?
Im looking into a fuel additive called Sta-Bil. I know little about any of these additives.
I run a little bit of 2 stroke oil in my gas. I stopped having problems.
  • Good Post
Reactions: HEC
   / Fuel stabalizer #59
Never have a problem with E10 and have been using it for decades. As others have said the problem isn’t E10 its the nature of gasoline in general. Likewise in my diesels I use an additive to protect against fuel gelling in winter even though I use winter blend and to protect against the microbes if diesel is left sitting too long.
   / Fuel stabalizer #60
The folks who don't use a stabilizer in there occasional use engines, and never have a bad fuel problem, I'd like to know which church they go to? ;) We can't do that and not have fuel go sour in a month. Seafoam costs $7 per can, cleaning out the fuel system of bad fuel runs 50 to $100+.
I'd call that cost effective for occasional use engines :unsure:....
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2019 Ford Fiesta SE Hatchback (A55853)
2019 Ford Fiesta...
2012 CATERPILLAR 303.5D CR EXCAVATOR (A52707)
2012 CATERPILLAR...
2014 Ford Explorer SUV (A56859)
2014 Ford Explorer...
2016 Cat TL1055D Telehandler (A55315)
2016 Cat TL1055D...
2012 CATERPILLAR 247B3 SKID STEER (A52707)
2012 CATERPILLAR...
