fuel solenoid
/ fuel solenoid #1
darrenjttu
Glen Rose, Tx
JD 4300
John Deere 4300 and I started having problems with the tractor shutting off after a while when it got hot. I searched this forum and found all the symptoms that my tractor as doing. I took off the fuel solenoid and the plunger was packed with oil. I cleaned it out and it works fine now but for how long? Has anyone found a solution to this common problem? People on the searches said that a new solenoid does not fix it and it is a common problem with the 4300. Any suggestions?
/ fuel solenoid
I bought the thermistor first for 5 bucks planning on changing it but when I couldn't find my soldering gun I just took the solenoid off and cleaned it. I don't know if I should change the thermistor since it has yet to shut off after I cleaned it out.
/ fuel solenoid #4
Wish I could help but I've got a 4200 with the same problem that a solution has evaded me.
Heat gun on the solenoid and pumping the charge pump usually works for me.
John Deere 980 30' Field Cultivator (A66285)
John Deere 980 30'...
International S1900 (A63689)
International...
New/Unused Quick Attach Backhoe Attachment (A65583)
New/Unused Quick...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
Dragline Bucket (A65640)
Dragline Bucket...
2013 JOHN DEERE S550 GRAIN COMBINE (A64277)
2013 JOHN DEERE...
