Oil & Fuel Fuel sensor/ gauge leaking fuel
   / Fuel sensor/ gauge leaking fuel #1
Bigjune
Jd 5320
There is fuel leaking from the bottom of my fuel tank from the fuel gauge sensor. Any advice on repair? Is it a seal or whole gauge. Fuel gauge seems to work ok. Just a constant drip along the wires going into the sensor on the tank bottom. (jd5105). Thanks for any help someone can offer.
   / Fuel sensor/ gauge leaking fuel #2
There is a gasket used for the sender will be either a thick rubber or cork material. Is also relativly close to the drain valve so will want to make sure is not traveling from there to sender wires.
Thanks. Will check. Tractor only has 250 hours and garage kept so I am at a loss as to why this occurred. I did notice wires hanging down from sensor so maybe something snagged on it and cracked sensor. Thanks for reply. I am going to check fuel drain before I change gasket.
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2020 FOR TRANSIT CONECT CARGO VAN (A52577)
2020 FOR TRANSIT...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
