Oil & Fuel Fuel sensor/ gauge leaking fuel
   / Fuel sensor/ gauge leaking fuel #1
Bigjune
Jd 5320
There is fuel leaking from the bottom of my fuel tank from the fuel gauge sensor. Any advice on repair? Is it a seal or whole gauge. Fuel gauge seems to work ok. Just a constant drip along the wires going into the sensor on the tank bottom. (jd5105). Thanks for any help someone can offer.
   / Fuel sensor/ gauge leaking fuel #2
There is a gasket used for the sender will be either a thick rubber or cork material. Is also relativly close to the drain valve so will want to make sure is not traveling from there to sender wires.
Thanks. Will check. Tractor only has 250 hours and garage kept so I am at a loss as to why this occurred. I did notice wires hanging down from sensor so maybe something snagged on it and cracked sensor. Thanks for reply. I am going to check fuel drain before I change gasket.
2004 Dodge Dakota Ext. Cab Pickup Truck (A50323)
2004 Dodge Dakota...
2004 Toro 74246 Turbo Force 60in Zero Turn Commercial Mower (A50322)
2004 Toro 74246...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52748)
2011 New Holland...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
40' CONTAINER (A51244)
Ford F-450 Utility Truck (A52748)
Ford F-450 Utility...
