fuel selinoid not energized
   / fuel selinoid not energized #1
Dlamb56
salem,mo
mahindra 3510
My 05' 3510 is not getting voltage to solinoid. checked wiring from solinoid to firewall, it is ok. Can't figure wiring in main harness (changes color?) Anyone have diagram on 3510 wiring or imfo. I'm thinking KEY SWITCH but want to make sure first. I have also checked all fuses. Any suggestions?
Thanks Dlamb
   / fuel selinoid not energized #2
Thanks Dlamb
You really should ask this under the correct topic, you might get better answers. While this problem is fuel related, its more of a repair, might want to move it to either repairs, or the Mahindra topic.
Check your owners manual, you might have some kind of safety switch. Are you getting power to the start solenoid? Are you getting power to other items on the machine? Is it cranking and just not starting?
You might want to search the Mahindra threads here, someone probably has had similar issues.
   / fuel selinoid not energized #3
Sorry about the mislocation of the post. I am new to the site and really enjoy it. Tractor runs and operates as always. I just have to pull the shut off cable manually.I tore into the dash yesturday,and think it may be a relay under (tucked away)console. Will call local dealer Monday(7-29).
Thanks for helping
Dlamb
   / fuel selinoid not energized #5
Thanks for helping
Dlamb
That's OK about being in the wrong section. Just if you were to put it under a different section you might have had better answers. In the future try and give a little more information. I didn't know if the tractor was running, not running, not shutting off.
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
BOMAG BW145D-40 SMOOTH DRUM ROLLER (A51246)
BOMAG BW145D-40...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2013 F-550 Bucket Truck (A53472)
2013 F-550 Bucket...
2014 Nissan Pathfinder SUV (A51694)
2014 Nissan...
