Oil & Fuel fuel return line hose clamp
   / fuel return line hose clamp #1
tmar04
YM 276
Where in the world can I get a small hose clamp for the fuel return hose, at the injector connection? Have a pesky leak and can't find a clamp small enough. must be about a 3/16 line, clear vinyl. thanks to all.
   / fuel return line hose clamp #2
The local hardware store should have some. Get the stainless steel threaded ones. They are a little more user friendly.
Or you could come up and search my tool box cause I know there will be one there somewhere. No charge.
Egon /forums/images/graemlins/grin.gif
   / fuel return line hose clamp #3
You probably need a new line. A non-pressurized hose that small shouldn't need a clamp.
   / fuel return line hose clamp #4
I agree, clear vinyl isn't the appropriate material for that line either..........
   / fuel return line hose clamp #5
If worst comes to worst and the leak persists, NAPA has fuel injection hose clamps in a ton of sizes. I use them all the time and they are much more effective then a regular style hose clamp. You have to tell them specifically you want a fuel injection clamp. If all else fails, go to your local car dealership (any make vehicle) and tell them you want a plastic "click lock" clamp for a 3/16 outside diameter hose. They should have one or be able to order one for you. If the parts dept. guy is even remotely helpful, he'll find it.
PM
   / fuel return line hose clamp #6
TMAr04
Try using a small zip wire tye on them i use them on fuel lines on my atvs and my ym2000a.
JOHN DEERE 520 SHREDDER LOT NUMBER 253 (A53084)
JOHN DEERE 520...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
1275 (A50490)
1275 (A50490)
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A53472)
2015 Ford F550...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
