Fuel pump suggestions
   / Fuel pump suggestions #1
Teikas Dad
Live Free or Die
Kubota B3200
I've gotten tired of lifting 5 gallon jugs to the top of the tractor to fuel it so I decided to build a fueling setup. I'm figuring a 30 gallon plastic drum with a 12v fuel transfer pump mounted on it. My question is related to pump brands. I've found Fill-Rite, GPI, Roughneck, Traveller and Troy brands. Is one brand better than the other, or maybe I should approach it this way...what brands are junk? I'm not going to be using it every day like a contractor would so I don't need one of the big buck heavy duty units.
Any advice would be appreciated.
   / Fuel pump suggestions #2
My Uncle uses the 30 gallon drums, but no transfer pump. He uses a shop, or small 12 volt, air compressor to "push" the fuel out rather than pump it.
   / Fuel pump suggestions #3
That is an easy solution. Thanks!
   / Fuel pump suggestions #4
Is there a reason you need an electric pump? I've used a hand crank pump for years. Even being crippled up with RA it is super easy to turn and get about 1/2 gallon per turn.
   / Fuel pump suggestions #5
I have 30 gallon drums too and use a $30.00 rotary crank pump from Northern Tool.
   / Fuel pump suggestions #6
I use a crank style hand pump. I've been debating getting a 12v pump. I have a nozzle with finger squeezed valve. I always end up needing someone to either pump or hold the nozzle.
   / Fuel pump suggestions #7
What type of sealant is to be used for 2600 Ford tractor for leakage on back side of injector pump after all gaskets have been replaced? Please, any suggestions?
2018 GENIE GTH-844 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-844...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
UNUSED DIGGIT 6'5"-16 DRAWER, 4 CABINET WORK BENCH (A54757)
UNUSED DIGGIT...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
2015 Chevrolet Tahoe SUV (A53424)
2015 Chevrolet...
