Fuel pump issue. Need HELP
   / Fuel pump issue. Need HELP #1
MLS5662
2420 Farm pro
I recently installed a new fuel pump on my little tractor and have an issue. I have primed the unit and have fuel with no air throughout the pump, however when I spin the pump over I cannot get fuel to come out of the injector ports on top of the pump itself. I have insured that the fuel shutoff lever is in the proper position but still get no fuel. Any suggestions will be appreciated.
   / Fuel pump issue. Need HELP #2
Do you have a wire or two going to the injection pump? if so you probably have a fuel solenoid valve, check for 12 volts with key on. Do you have an electric or manual fuel pump? If electric, remove the discharge from the pump and turn the key on to see how well it pumps, if you can't get it to pump connect the wires to the battery.
Good luck.
It is a manual pump, activated by a gear that connects directly to the engine. There are 2 wires that are and were connected to the previous pump but I think that they are grounds.
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
