Fuel pump issue. Need HELP
   / Fuel pump issue. Need HELP #1
MLS5662
2420 Farm pro
I recently installed a new fuel pump on my little tractor and have an issue. I have primed the unit and have fuel with no air throughout the pump, however when I spin the pump over I cannot get fuel to come out of the injector ports on top of the pump itself. I have insured that the fuel shutoff lever is in the proper position but still get no fuel. Any suggestions will be appreciated.
   / Fuel pump issue. Need HELP #2
Do you have a wire or two going to the injection pump? if so you probably have a fuel solenoid valve, check for 12 volts with key on. Do you have an electric or manual fuel pump? If electric, remove the discharge from the pump and turn the key on to see how well it pumps, if you can't get it to pump connect the wires to the battery.
Good luck.
It is a manual pump, activated by a gear that connects directly to the engine. There are 2 wires that are and were connected to the previous pump but I think that they are grounds.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2018 Generac S/A Towable Light Tower (A52377)
2018 Generac S/A...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2018 International DuraStar 4300 TMA Attenuator Truck (A52377)
2018 International...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
