Fuel pump continues to run with key out of tractor
   / Fuel pump continues to run with key out of tractor #1
breadtrk
Platinum Member
ashland city, tn
XR 3037 HST Cab
Recently my XR3037 fuel pump and started to continuously run, even with the key out of the tractor. I have to unhook the main relay by the battery to get it to stop.
Anyone had this issue yet?
   / Fuel pump continues to run with key out of tractor #2
XG 3032 - Yesterday afternoon when I turned off the ignition after a regen finished I heard a clicking sound around the steering wheel area. Thinking it would stop on its own I came in for the day.
This morning when I went out to start it the clicking sound was still happening. I started it as usuall but noticed the batt seem slugish.
Ran tract off and on for 3 hours and last timed I shut off the tractor I once again heard the clicking sound.
The clicking ended up coming from the fuel pump relay. It was hot. I swapped it with another relay of the same number but the clicking started again as soon as I inserted the other relay.
I will check and clean grounds and update this thread if and when I find the cause.
   / Fuel pump continues to run with key out of tractor #3
   / Fuel pump continues to run with key out of tractor #4
I’m having the same issue. Did you find out a fix for it yet?
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2002 STERLING LT9500 DAY CAB (A51222)
2002 STERLING...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
