Fuel pump continues to run with key out of tractor
/ Fuel pump continues to run with key out of tractor #1
breadtrk
ashland city, tn
XR 3037 HST Cab
Recently my XR3037 fuel pump and started to continuously run, even with the key out of the tractor. I have to unhook the main relay by the battery to get it to stop.
Anyone had this issue yet?
/ Fuel pump continues to run with key out of tractor #2
XG 3032 - Yesterday afternoon when I turned off the ignition after a regen finished I heard a clicking sound around the steering wheel area. Thinking it would stop on its own I came in for the day.
This morning when I went out to start it the clicking sound was still happening. I started it as usuall but noticed the batt seem slugish.
Ran tract off and on for 3 hours and last timed I shut off the tractor I once again heard the clicking sound.
The clicking ended up coming from the fuel pump relay. It was hot. I swapped it with another relay of the same number but the clicking started again as soon as I inserted the other relay.
I will check and clean grounds and update this thread if and when I find the cause.
/ Fuel pump continues to run with key out of tractor #3
/ Fuel pump continues to run with key out of tractor #4
I’m having the same issue. Did you find out a fix for it yet?
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2005 JLG Skytrack 10054 10K Capacity Telehandler (A59213)
2005 JLG Skytrack...
