Oil & Fuel Fuel problems with BX2200
   / Fuel problems with BX2200 #11
rdsaustintx said:
Why would it lose power in 20 minutes??
<scratchin head>
Probably takes about that long to get good and hot from the pre-ignition/higher cylinder pressure caused by the gasoline...:(
   / Fuel problems with BX2200 #12
How did you find out they had gasoline in their tank? If you have proof and take them to court I can't see where they would have a leg to stand on. Their direct negligence damaged your engine. I'm no lawyer but it sounds pretty cut and dried to me.
I had gone thru changing the fuel filters, blowing back thru the line to the tank then after talking to a Kubota shop manager, changing the fuel pump. None of these helped. I then decided to drain the tank (suspecting contaminated fuel) and refilled from my neighbor's fuel can and amazingly the BX started to run better. After refilling the tank out of his can I popped the lid on my second can of fuel and could immedeately smell the gasoline in the fuel.
Ran BX pulling the same disk for 45 min. with no problems and today I cut 3 acres of grass, again with no problem.
Also my neighbor smelled the gas in both of the cans.
I suspect that as the gas hits the injector pump and is heated ( after running the tractor for a while), that the gas may tend to vapor lock the injector pump. Another explanation may be that diesel, being a heavier liquid than gas tends to separate when sitting and the tractor when restarted gets almost pure diesel until run for a while. I don't know-just guessing.
You may ask why I did not smell the gas when working on the BX, I had app 3 gal. of diesel in the tank and just topped up the tank with the diesel/gas mixture.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2013 Ford F-150 (A55973)
2013 Ford F-150...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
