Fuel problems no gas from carb. To spark plugs
   / Fuel problems no gas from carb. To spark plugs #1
1952 John Deere model mt
Fuel problem no gas carb. To spark plugs.
   / Fuel problems no gas from carb. To spark plugs #2
Welcome.
We will need more information about the problem and description of what "to spark plugs" means.
Also FYI it is generally not prudent to disclose your personal email address in a public forum (your user name)
   / Fuel problems no gas from carb. To spark plugs #3
take plugs out, dump a bit of gas in the cylinders, put plugs back in and start it! It gotta be primed to get it to start suckin gas on its own. Got 420's here the same way.
   / Fuel problems no gas from carb. To spark plugs #4
It's probably the float needle valve is stuck in the carb and can't open up to fill the float bowl with gasoline. Modern gas causes that to happen if the carb sits with too long with old gas in it and especially if the tractor sits all winter with the gas tap still turned on... or if it is a leaky tap.
You can take off the carb, clean it up and put a carb kit in it.
Or alternately, do the minimum: Just take off the float bowl, clean up the float valve needle, and reassemble. No kit needed, but you may need a new float bowl gasket.
I do that ot ours nearly every spring. Of course some years I do remember on the last tractor run of the season to turn off the gas and run it until the carb float bowl runs out of fuel. When I do, I don't have to take it apart and clean the carb float needle next spring.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
10 Caterpillar Keys (A49346)
10 Caterpillar...
1998 Caterpillar TH63 6,000LB 4x4 Rough Terrain Telehandler (A49346)
1998 Caterpillar...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A48081)
2005 Toyota Tundra...
UNUSED White Metal Roof Panels (A50860)
UNUSED White Metal...
2007 Mack CTP713 Granite T/A Roll Off Truck (A48081)
2007 Mack CTP713...
