Fuel problem in 2740
/ Fuel problem in 2740 #1
uphere
Ontario, Canada
I decided to change my fuel filter today - with the loader setup it is a bit of a chore - but got it done. I thought. Started up ran for 2 minutes - died. Purge the air again - reinstalled the filter a couple times thinking I might have a slight air leak somwehere. But to no avail. It turns over but does not start. Any ideas as to how I should continue to @#$% this up! :)
/ Fuel problem in 2740 #2
I have a fuel filter setting in my shop; and now am a bit wary about putting it on. Have you got her started yet?
Yeah - mechanic from the dealer came out to the farm and spent an hour getting air out of my system ... it just did not want to cooperate. We tried letting air out at the injectors but we couldn't seem to get any fuel to show up? But we stayed with it and she finally coughed and went. He tells me that the little diesels are a real pain for air problems - I know from my own experience with my old IHC (624) that this would seem to be true (no problem with the IHC).
/ Fuel problem in 2740 #4
open up the fuel line on the last injector in the system and turn over eventually fuel will seep out, then close the line. do you have it at least as far as the bowl?
thanks Shakin ... actually we ended up opening the first and last to get it to work (you can't get at the middle one unless you take one right out?). We had little fuel if any in the bowl - took some time but after a bout of swear words from the mechanic she finally "seeped"!
/ Fuel problem in 2740 #6
How did you get bowl off with loader frame in the way?
I’m getting ready to repair a gas leak and I don’t know if pulling off the front loader framework will have to be done.
Did you have to remove loader frame work?
SHOPBUILT T/A TRAILER (A63291)
SHOPBUILT T/A...
2009 Chevrolet Tahoe SUV (A61574)
2009 Chevrolet...
H&H 500 GALLON T/A SPRAYER (A63291)
H&H 500 GALLON T/A...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
2006 Honda Odyssey Van (A61574)
2006 Honda Odyssey...
CADMAN 4500 WIDE BODY HARD HOSE TRAVELER (A63291)
CADMAN 4500 WIDE...
