Fuel Problem for Allis 180
   / Fuel Problem for Allis 180 #1
Anonymous Poster
Epic Contributor
I have recently had a problem with my Allis Chalmer 180 gas tractor, It starts and idles fine but when i give it more gas it sputters and dies. In have tried new jets in the carb, blowing out the gas line from the sediment bowl to the tank. If anyone has a suggestion I would greatly appreciate the help.
   / Fuel Problem for Allis 180 #2
I found out always try the little things first as you did.
Could moisture be in your gas tank..little dry gas may help.
If the tractor has a fuel fitler does it need changing.
When the new jets were install was the engine warm before adjustments,if not you may have to adjust.
What color smoke comes out of your exhaust and does it restart hard,for it maybe getting to much gas.
Check to make sure your choke is fully open,also see if there gas kinda dripping from the carb.
Hope this helps.
Thomas..NH /w3tcompact/icons/wink.gif
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
SCAN FOR HAULING AND FINANCING INFORMATION (A51247)
SCAN FOR HAULING...
2025 Mower King SSECAG-Y (A50123)
2025 Mower King...
(8) 5' X 20' X 3/8" STEEL PLATES (A51248)
(8) 5' X 20' X...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
