Hello folks. I am a newby so bear with me, all guidance appreciated.
I have a Farmall Super A / McCormick that I can't keep running. I can crank it with the choke pulled and it will idle, but try to take the choke off and/or add throttle it quits. Pull the choke give it a little throttle it cranks and runs at idle. I had a leaking sediment bowl that I could not stop so I replaced it with a new one, It appears to work like it should. I took the fuel line loose from the carb and there is a pretty good flow. Can someone describe how to tell if flow is sufficient? Carburators are not my strong suit and I know even less about govenors. Has anyone had siniliar issus or can anyone help?
