Fuel Prices--Will They Effect Your Tractor Usage?
   / Fuel Prices--Will They Effect Your Tractor Usage? #11
Around here the price of Diesel is around $3.38 a gal and regular gas was $2.89-9 today when I filled up the car. (Wish they would drop that 9/10ths of a penny)
As for the tractor it will be used when needed, but not just to go down and get the mail! Still have to drive everyday somewhere so the trips just cost more.
The TV folks are talking about retail stores hurting with sales being way off, well I am sure in the Northeast it will be real slow for them this year. Heating fuel cost are expected to be up a minimum of 18% so most of our Christmas joy will go into heating oil!
This is our first week with below freezing temperatures every morning and the heat on all day long.
   / Fuel Prices--Will They Effect Your Tractor Usage? #12
Oleozz said:
It uses about 6--8 gal an hour to operate so it will cost me over $20 an hour just for fuel. ?
What are doing to burn 6-8 gallons an hr? Is this with your Kioti?
My L 5240 burns 1.5 hr doing logging or light grading work.
No, it's with an IH 1066.
   / Fuel Prices--Will They Effect Your Tractor Usage? #14
Hi
All these examples do NOT imply that gasoline is cheap; It just illustrates how outrageous some prices are.... You will be really shocked by the last one!!!! (At least, I was...)Think a gallon of gas is expensive?
This makes one think, and also puts things in perspective. Diet Snapple 16 oz $1.29 ... $10.32 per gallon
Lipton Ice Tea 16 oz $1.19 ..........$9.52 per gallon Gatorade 20 oz $1.59 .... $10.17 per gallonOcean Spray 16 oz $1.25 ......... $10.00 per gallonBrake Fluid 12 oz $3.15 ......... $33.60 per gallonVick's NyQuil 6 oz $8.35 ... $178.13 per gallon Pepto Bismol 4 oz $3.85 .. $123.20 per gallonWhiteout 7 oz $1.39 ...... . $25.42 per gallonScope 1.5 oz $0.99 .....$84.48 per gallon And this is the REAL KICKER...Evian water 9 oz $1.49..........$21.19 per gallon!$21.19 for WATER And the buyers don't even know the source . (Evian spelled backwards is Naive.) Ever wonder why computer printers are so cheap? So they have you hooked for the ink.Someone calculated the cost of the ink at................ You won't believe it................... But it is true......................... $5,200 a gal. (five thousand two hundred dollars) So, the next time you're at the pump, Be glad your car doesn't run on Water, Scope, or Whiteout, Pepto Bismol, NyQuil Or God forbid, Printer Ink!!!!!
   / Fuel Prices--Will They Effect Your Tractor Usage? #15
Wow, how big is the engine in that thing? It sounds like it needs new injectors. Does it put out a lot of black smoke? :confused: My D6 uses a little more than 3gph.
   / Fuel Prices--Will They Effect Your Tractor Usage? #16
Well, I tried NyQuil...but the tractor kept snoozing off...:D
   / Fuel Prices--Will They Effect Your Tractor Usage? #17
But did it quit sneezing, that is the question?
   / Fuel Prices--Will They Effect Your Tractor Usage? #18
I insure an in woods chipping contractor. He told me about a month ago that his weekly fuel bill has been running about 18K/week. That is including his trucking. Can you imagine the impact these prices are going to have on him!!
   / Fuel Prices--Will They Effect Your Tractor Usage? #19
That seems like quite a bit an hour. I figured that it would use about 5 gallon per hour. My 166 HP Perkins uses about 6 gph at about 3/4 pull and 7-8 gph at full pull. The only fuel that I will able to get at a reasonable cost this winter will be propane. I contracted 20,000 gallons at $1.56 a gallon.
Many of the folks on the IH site that run 1066's claim they will use 6 gph and if you are doing heavy pulling it will go up to 8-9 gph. I really won't know until spring when I plow and disc with it.
EZGO (A50324)
EZGO (A50324)
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
1267 (A50490)
1267 (A50490)
72In FEL HD Round Back Bucket (A52748)
72In FEL HD Round...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
