Fuel Pickup Tube Replacement
/ Fuel Pickup Tube Replacement #1
Tandem
Wet Coast, NZ
Pasquali XB40
I am about to replace a fuel pickup tube that broke off due to deterioration. This seems to be a common problem with Bobcats.
Why are these tubes made of vinyl? Is it a bad idea to use rubber fuel line instead?
/ Fuel Pickup Tube Replacement #2
I think rubber would tend to curl up and not pick up all the fuel.. The plastic or vinyl would stay straight and stay a little bit off the bottom of the tank....
/ Fuel Pickup Tube Replacement #3
if you use rubber put a length of stainless wire inside to prevent it curling and a loop on the end to keep it off the bottom of the tank, thats what we did on our sons machine and it works fine
Sorry for the late reply.
At the end I ended up using the vinyl line supplied with the screen. Just had to heat it up in order to straighten it first.
/ Fuel Pickup Tube Replacement #6
I found that vinyl when used with fuel goes hard an brittle.
For my fuel pumping I went to radiator hose and that remains nice and flexible even under cold.
Also radiator hose is designed for the oily fuel environments.
