Oil & Fuel fuel oil
   / fuel oil #1
cabin kioti
Bronze Member
Sullivan County Pennsylvania
ck 30 hst
I was just reading in one of the forums that home fuel heating oil could be used in a diesel engine. Aside from the tax issue I always thought the there was a problem with lubrication. I have a 2006 CK30 bought new, that has been one heck of a tractor and I really do not want to mess up something. I use off road fuel with opti lube and never had a problem starting, or engine preformance. Just wondering.
   / fuel oil #2
Home heating oil is diesel fuel,it`s just got a red color additive so the tax man can tell the difference.
   / fuel oil #3
Close, but not exactly.
I believe diesel fuel has additives that HHO or kerosene does not. The additives are in diesel fuel for the benefit of engines. (lubricity, anti-foam agents, etc)
You can run HHO or K-1 in a diesel engine, but a steady diet of it would not be good idea. (some engine manufacturers may consider your warranty void if you do)
As far as the tax issue goes, can use "off-road" diesel fuel in your tractor. Here in La, off-road is ~$.35 per gallon cheaper than road fuel.
Do a search, and you can read for days on this issue. :D
   / fuel oil #4
Home heating oil and diesel are one and the same up here in Northern Ontario. My supplier just puts the red dye into the HHO to show that it is 'tax free'.
   / fuel oil #5
Our store sells it as Furnace oil/off road diesel. It is ussually 4cents cheaper a litre than on road stuff.
2024 John Deere 6110M (A50120)
2024 John Deere...
2014 Ford Fusion Sedan (A50324)
2014 Ford Fusion...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2016 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A50323)
2016 Mack CXU613...
