Fuel Nozzle Question
   / Fuel Nozzle Question #1
NCMau
NC
MF 202/Ford 8N
I recently acquired an OPW 11B fuel nozzle that that does not allow the fuel to go through when I squeeze the trigger.
According to the specs, the nozzle remains closed until there is pump pressure. My pump caddy develops 20 GPM which I believe should be enough to activate the valve.
The nozzle itself looks like it had a very little usage. What I would like to know if there is a possibility to fix it or bypass this pressure valve and just use it with a trigger release.
   / Fuel Nozzle Question #2
Gallons per minute is not pressure, its a measure of flow. You could get 20gpm at .01psi or 100psi, depending on the pump. You probably need to check the pressure on the pump when its running. I assume it has a pressure relief valve to prevent it breaking things when the nozle is closed, but you might want to check.
   / Fuel Nozzle Question #3
My auto-shutoff nozzle developed an issue where it also doesn't want to release the flow. I have to click the handle several times and it will finally open the valve. I don't know what caused it to do that, but I don't think it is pressure from the pump that opens it. I think it has something to do with that little internal pipe that terminates close to the end of the nozzle. If it gets liquid in it, it stops the flow. I think I may have an obstruction there (like a spider web or other object that is restricting the backflow.) I don't see any easy way of checking it or removing and cleaning it either. I do have another hose nozzle without the auto shutoff feature ready to use if the other one finally craps out.
   / Fuel Nozzle Question #4
The little hole/tube at the end of the nozle leads to a pressure sensor. When the tank fills up enough to push some some fluid into that tube/hole, it trips the pressure sensor & causes the valve to pop closed & stop filling the tank. Any obstruction of that hole or tube will stop auto-shutoff from working. I'd imagine the pressure sensor is pretty sensitive, so it wouldn't be hard to throw out of calibration or what not.
My F250 with a service body has a kink or something betwwen the filler & tank, so I have to get the nozle in the filler just right or it will trip all the time. Sometimes I just have to hold it manually.
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2016 KENWORTH W900 T/A DAY CAB ROAD TRACTOR (A51406)
2016 KENWORTH W900...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A52377)
2007 Reitnouer 40...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
