Fuel Nozzle Question
   / Fuel Nozzle Question #1
NCMau
NC
MF 202/Ford 8N
I recently acquired an OPW 11B fuel nozzle that that does not allow the fuel to go through when I squeeze the trigger.
According to the specs, the nozzle remains closed until there is pump pressure. My pump caddy develops 20 GPM which I believe should be enough to activate the valve.
The nozzle itself looks like it had a very little usage. What I would like to know if there is a possibility to fix it or bypass this pressure valve and just use it with a trigger release.
   / Fuel Nozzle Question #2
Gallons per minute is not pressure, its a measure of flow. You could get 20gpm at .01psi or 100psi, depending on the pump. You probably need to check the pressure on the pump when its running. I assume it has a pressure relief valve to prevent it breaking things when the nozle is closed, but you might want to check.
   / Fuel Nozzle Question #3
My auto-shutoff nozzle developed an issue where it also doesn't want to release the flow. I have to click the handle several times and it will finally open the valve. I don't know what caused it to do that, but I don't think it is pressure from the pump that opens it. I think it has something to do with that little internal pipe that terminates close to the end of the nozzle. If it gets liquid in it, it stops the flow. I think I may have an obstruction there (like a spider web or other object that is restricting the backflow.) I don't see any easy way of checking it or removing and cleaning it either. I do have another hose nozzle without the auto shutoff feature ready to use if the other one finally craps out.
   / Fuel Nozzle Question #4
The little hole/tube at the end of the nozle leads to a pressure sensor. When the tank fills up enough to push some some fluid into that tube/hole, it trips the pressure sensor & causes the valve to pop closed & stop filling the tank. Any obstruction of that hole or tube will stop auto-shutoff from working. I'd imagine the pressure sensor is pretty sensitive, so it wouldn't be hard to throw out of calibration or what not.
My F250 with a service body has a kink or something betwwen the filler & tank, so I have to get the nozle in the filler just right or it will trip all the time. Sometimes I just have to hold it manually.
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
2014 PETERBILT 386 DAY CAB (A54607)
2014 PETERBILT 386...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
