Fuel line
   / Fuel line #1
stormpetrel
Block Island R.I.
ym2210D
I was bush hogging last night when I started getting the signs of sucking air. Plenty of fuel in the tank; so I bled the system. Wouldn't run. I'm getting fuel out the injector pump side from both lines, but only one cylinder is getting fuel.
My question is: can the line be cleaned/blown out? Or do I need a new one?
   / Fuel line #2
If the line is blocked somehow and the injection pump won't push it free, I don't think you'll be able to blow it out with compressed air. The injection pump operates at vastly higher pressure than a home air compressor will provide through a nozzle.
How did you isolate that one cylinder is lacking fuel? Have you determined which cylinder?
By the time the fuel has gone through the filter, injection pump and to the lines, there shouldn't be anything that could block the line. The clearances in the pump are miniscule. I don't see how anything could get through there and be capable of occluding the high pressure line.
   / Fuel line #5
If you know you are getting fuel at the injectors on both cylinders it would sound like an injector problem to me. Went back and re read your post and guess I didn't understand it the first time. Are you saying no fuel will come out when you crack the line at the injector?
   / Fuel line #6
So you can see fuel coming out of the lines on top of the injectors if you crack them there? If so i agree an injector problem.
   / Fuel line
I posted.....then got a little busy. Sorry for the confusion; the injector (fuel) pump was showing fuel at both lines. The rear cylinder did not have fuel. I was able to blow the line out, and the tractor is up and running.
As an aside, that engine is not easy to bleed the air out of!!!! I am very familiar with the process, use the lift pump to make sure the injector pump has fuel, then crack the lines at the pump, then at the injectors. But, even AFTER I have fuel at the cylinders, close the nuts and fire her up, the engine runs briefly and dies. I then have to crank her over for a while with the compression release engaged to get her to fire. It's a pain in the butt, much more difficult than with any of the other diesel engines I have dealt with!!! I always use the compression release, and make sure I have the fuel lever engaged (I only had to make THAT mistake once!!) so she spins freely and sends fuel toward the cylinders. I'm used to engines that fire back up and run, or, at worst, sputter some before they get going good.
   / Fuel line #8
You might try the bleeding procedure recommended for YM2000. I thought your fuel system was identical.
Open the left (input) bleed screw at the top of the fuel filter; close it after no more air comes out.
Same at right (output) bleed screw.
Same at bleed screw down on the injector pump inlet banjo.
Using that procedure, I've never had to open the lines on the high pressure side of the injector pump.
   / Fuel line #9
I've never had to do more than the bleed screws at my fuel filter housing. Change my filters every year.
   / Fuel line
Well......it happened again:mad::mad::mad:. I removed the line, acid washed it, ran a thin wire through it, blew it out with carb cleaner, and otherwise got the thing squeaky clean. no fuel to the rear cylinder. Just ordered a new ($350) injector pump. Sheesh...........:(
Funny thing is I had it running fine. This may be the answer to why it was so hard to bleed the air out!!! (very low fuel presssure to that cylinder) Hopefully, she'll bleed much easier in the future:thumbsup:
P.S. Is changing that pump as easy as it looks? Four nuts and off?
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A53473)
2016 KBH...
2020 Bell B30E Off Road Dump Truck (A53117)
2020 Bell B30E Off...
2003 International 24ft 4200 Box Truck (A51692)
2003 International...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
