fuel line repair or replace??Yanmar 1500
   / fuel line repair or replace??Yanmar 1500 #1
cliff880
Both fuel lines that originate at the fuel pump and terminate at the injectors have worn and are leaking where the lines bend around the front of the engine block.I removed the lines and tried wrapping them with copper wire impregnated with JB Weld thinking that since they were small holes then this would work,it didn't Any ideas??
Cliff880
   / fuel line repair or replace??Yanmar 1500 #2
Replace them . Check some dealers on the yanmar section. They may have some parts tractors or a line set that will work
   / fuel line repair or replace??Yanmar 1500 #3
This is about the only repair that I have had to do that wasnt self inflicted, I used auto parts store fuel line and gave it a little twist before clamping
   / fuel line repair or replace??Yanmar 1500 #4
Save yourself the trouble later. Replace them.
   / fuel line repair or replace??Yanmar 1500 #5
If the fuel line stopped your leaks, let it ride till you have another problem. No since wasting money.....
   / fuel line repair or replace??Yanmar 1500 #6
Cliff880
Might have fixed a suction line.. but since those are multi-thousand psi lines.. I wouldn't have even trried that.
braze them.. run some extra brass around the areas with the most wear.
I have used brazed hyd lines with no problem..
soundguy
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A52576)
2015 KENWORTH T370...
2004 Sterling Acterra Truck Cab & Chassis S/A (A51692)
2004 Sterling...
Set of AG R4 Wheels and Tires (A52748)
Set of AG R4...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
