Fuel line connector problem
   / Fuel line connector problem #21
The tire valve trick will work but I would use a high pressure valve stem that one you push through and put a nut and rubber washer on the outside, but you would have to takke the sending unit out to place it in the hole the other option would be to buy a 1/4 inch NPT bulkhead fitting for air and a rubber washer they would go through the tank and then you would place a nut and tighten on the outside.
Kenny kkegris@yahoo.com
Weber CR5 Reversible Plate Compactor (A56857)
Weber CR5...
202476 (A54757)
202476 (A54757)
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
10ft Pace American Enclosed Cargo Trailer (A55853)
10ft Pace American...
1996 Sunflower 1543-38 Folding Disk (A56435)
1996 Sunflower...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
