Oil & Fuel Fuel light on all the time. Runs out of fuel with quarter tank showing.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #1
Mad Mac
Grapeland, TX
Mahindra 5555
When you look into the tank there still seems to be fuel. It's a minor inconvenience but is there an easy fix?
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #2
Sounds like a problem with the pickup tube?...Bent?
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #3
I'd say it's more likely that the level sensor isn't calibrated correctly. It's usually just a pot on a swinging arm with a float.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #4
If there is actually fuel in the tank, then it's not an issue with calibration. If the OP is mistaken, and the fuel is actually pretty much gone, I'd agree with this assessment.
OP, how much fuel does it take to fill the machine back up completely when it runs out - and how does that amount compare to the stated capacity of the fuel tank?
My operator uses a 5-gallon diesel jug to refill. It holds 12. I'll check with him tomorrow.
Thank you one and all, but a fix does not sound simple.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #6
I don't have a working fuel gauge on any of my tractors. But... I do have a wood stick. :) It's about 3/4"x1/2" and 18" long. It's more accurate than any fuel gauge when determining 1/4 tank increments.
   / Fuel light on all the time. Runs out of fuel with quarter tank showing. #7
If you ever have to restart a big diesel (I'm talking 671 Detroits), you will NEVER let that thing get below a 1/2 tank EVER again. This happened to me when I had to take over for an operator on a huge Euclid dump truck that went home sick (I was 19 and I'm 66 now...). Took me 3 hours to get it to "catch"....Keep them filled....BobG in VA
Sensible suggestions. Thank you.
Okay. It takes a little more than 10 gallons to top off the 12 gallon tank. So the calibration is off. We just need to refill it before it gets down to a quarter of a tank.
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
TEST YOUR BID BUTTON! (A51248)
TEST YOUR BID...
UNUSED FUTURE CYHC HYD SIDE SHIFT FORKS (A51248)
UNUSED FUTURE CYHC...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
