Oil & Fuel Fuel leak after filter change
   / Fuel leak after filter change #1
ah64driver2002
Ozark
Ford 3000
I just did my 50 he filter change and I am having an issue with the water sensor dripping fuel. The manual sucks on maintaining this thing. Is there something I should try before I go buy a new sensor. It was tight and still dripped so I backed it off and still the Sam issue. Any help would be appreciated
   / Fuel leak after filter change #2
Think mine had an o-ring.
I took the old o-ring off and re-used it. It's not leaking where it screws on. It dripping out of the hole that drains water out if you need to.
   / Fuel leak after filter change #4
Are you positive that fuel is not leaking from above, running down the back side and onto the drain. If you didn't jack with the drain, it should not be leaking there. It likely has a rubber washer or o-ring seal also that could have been damaged if you opened it.
I have found that it is better to pay the $5 for a new o-ring when changing filters since the old one is usually stretched out of shape (usually too large for the fit).
This is my first filter change so I didn't realize the water sensor would need to be swapped over. So they didn't tell me I might need to replace the o-ring. So I re-used the one from old filter. It is definitely coming out of the drain hole where water would drain out if you needed to do that.
   / Fuel leak after filter change #6
I have this same issue. Did you ever figure it out?
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
https://www.facebook.com/LipoExtremeDropsReviews/
https://www.faceboo...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2007 MACK CV713 WINCH TRUCK (A55745)
2007 MACK CV713...
Yellow Steel Diamond Plate (A55758)
Yellow Steel...
