Fuel injector pump removal
   / Fuel injector pump removal #1
PaulNY
I need to remove the injector pump on my ford 1983 ford 1710 3 cyl diesel tractor to access a leaking freeze out plug. How difficult is the removal and more importantly proper replacement of pump. Thanks for any advice.
   / Fuel injector pump removal #2
Make sure that you mark the housing and block for alignment purposes on install. Do not turn the injector pump rod or the motor over. This will keep everything lined up for the install.
   / Fuel injector pump removal #3
JimR has all the bases covered /forums/images/graemlins/cool.gif, just pay close attention to how you dis-assemble!
72'' root grapple (A53421)
72'' root grapple...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53473)
2012 UNVERFERTH...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2014 CATERPILLAR 289D SKID STEER (A52706)
2014 CATERPILLAR...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
Unused Delta Crash...
