Fuel injector leak help please
/ Fuel injector leak help please #1
outcrydrummer
Liberty
White Field Boss 31
So ive found a few posts but i have a white field boss 31 that leaks a constant drip from the overlow tube of what im guessing is the governor breather on the back of the injector pump.
I found a part listing in agco but parts house says the pump is discontinued........
From what i have read diesel is leaking past a seal in the injector pump and filling the lifting pump with diesel causing it to overflow while running and drip out of the governor breather line. Is this correct? The line comes from the upper back part of the injector.
So without a new replacement from agco does anyone know any other options?
Ive heard to drain it and refill with oil and i can limp it along like that.
Could anyone tell me what im suppose to drain and then fill exactly?
Sorry i have virtually no tractor experience.
/ Fuel injector leak help please #2
I'm sorry that I can't give you a direct answer because I'm not familiar with your fuel system. Have you tried your nearest AGCO dealer or a diesel shop that repairs injector pumps?
I tried to get a new injector pump from agco with no luck. Havent tried any local places for a rebuild yet. I did however find a few shops online that deal with those injector pumps specifically but they quoted me upwards of 600 for a rebuild......
Is that a fair price?
I also found a pump for 500 on a japanese ebay type site but im worried about getting scammed lol
/ Fuel injector leak help please #4
Is it a fair price? 600 $ for a rebuild and calibration on a test stand seems reasonable to me, now if there just going to disassemble and replace seals and gaskets id say it's high.
Your pump has it own lube oil separate from the engine, and it should be changed occasionally.
If you could post a decent photo of the injection pump I could try to identify the fill and drain plugs for you.
I actually just found the drain and fill level plug on it. Full of fuel as expected. I drained it and filled with engine oil. Honestly im a little surprised by the lrice of a rebuild
/ Fuel injector leak help please #6
Injection pump repair requires special test tools and training and they don't like to share trade knowledge so they can charge whatever the market will bare.
Around here it's a 1000$ Canadian for a shop just to look at a pump.
Is there is a small transfer pump mounted on the side of of your injection pump?
I dont see any sort of transfer pump bolted to the injector pump.
The price just caught me off guard since im not a diesel guy. Just seemed pretty expensive for a fuel injector pump haha.
/ Fuel injector leak help please #8
$600 is pretty standard shop charge to rebuild a pump. Doubtful you should have to buy a new one. Have you checked to make sure that your return to tank line isn't clogged? If you have a dealer nearby, drop by and talk to the shop people. They maybe able to give you some hints.
I havent checked the return line yet. That would be awesome if that was all it was.
Thanks
/ Fuel injector leak help please #10
Can you send me a link of the inj. pump break down.. I'm having trouble linking which type of pump you have..
I think I can help.. TPG
I cant find a diagram anywhere but on the agco site and they dont break down the pump any. Its in their parts book for the field boss 31. Let me see if i can get the link.
Thanks
/ Fuel injector leak help please #14
under the cover is access to the barrel and plungers, pump adjustments are inside.
The round looking thing with the two hoses is a transfer pump.
/ Fuel injector leak help please #15
You see that BIG NAME PLATE on the side of it?? all you had to do was say its a Diesel Kiki 3cylinder inline pump w/ an attached governor & get the #'s...
Unless the lift pump is leaking into the injection pump.. It has to be, the plungers & barrels are leaking..
Those are the mechanisms inside the pump that actually pump the fuel..
Over time they will get worn & start to loose their tightness & leak fuel.. the only cure is to replace them..
BUT.. its no big deal.. just shut your fuel off at the tank EVERY TIME you get done using it & check the oil in the pump often..
A rebuilt pump w/ new p&b's is gonna run around 1000.00.
One thing YOU COULD CHECK.. is the torque on the top nuts, called the delivery valve holders.. where the injector lines hook up to the pump.. Loosen the clamps that are supposed to be holding them tight..
And re-torque them to 35 FTlbs.. They loosen up over time and the gasket underneath them vibrates and becomes loose.. breaking the seal between the parts & allowing the fuel to seep into the pump..
YOU MUST USE A TORQUE WRENCH..
There are only 3 options here.. 1>Leaking lift pump.. 2>Loose DV holders.. 3> Worn P&B's.. #3 requires pump removal and lots of money.
2014 Jeep Wrangler 4x4 (MPV), VIN # 1C4BJWDGXEL206125 (A65579)
2014 Jeep Wrangler...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
NEW 2025 Mini Skid Steer Stand On Loader (A62679)
NEW 2025 Mini Skid...
2022 EZ-GO ELITE...
2011 CASCADIA 6X4 T/A DUMP TRUCK (A59914)
2011 CASCADIA 6X4...
