Fuel in Oil
   / Fuel in Oil #1
Rednec
I have a 1998 Farmtrac 60 (500hrs), anyway, ive noticed its making oil. Im suspecting injector pump, primarily diaphram. Is this something i can replace myself, i dont see the sense in rebuilding pump completley, $500-$700?
thanx
   / Fuel in Oil #2
If it has a mechanical lift pump,that could where fuel is getting in to the crankcase.
   / Fuel in Oil
It doesnt have mechanical lift, it does have a primer attached to side of inj pump..if i take off injector pump, how can i assure that i can put this back on without changing timing? Also,if its the diaphram cant i change thi swithout having thw whole the rebuilt, why would i need rebuild ?
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2022 KMC 5610 LOT IDENTIFIER 197 (A53084)
2022 KMC 5610 LOT...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
10' CONTAINER (A51248)
BESTWAY AG VSK50 LOT IDENTIFIER 96 (A53084)
BESTWAY AG VSK50...
