Fuel guage troubles
   / Fuel guage troubles #1
Indydirtfarmer
Platinum Member
Southern Indiana
JD 2440/4440/4020/4955
Trouble in paradise.... /forums/images/graemlins/tongue.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/frown.gif
Last week, as we were finishing up planting a corn field, the fuel guage on my '78 Deere 2440 started doing strange things. It began flipping back and forth between full and empty. (with a relatively full tank) It seemed to do it worse with high engine RPM's or higher ground speeds (on the road) /forums/images/graemlins/crazy.gif /forums/images/graemlins/shocked.gif
Fast forward to yesterday... I had to do some bush hogging around the homestead. I fueled up the 2440. (I didn't pay any attention to the guage BEFORE fueling) When I started mowing, I noticed the fuel guage was dead on empty. (with full tank) When I shut off the tractor (to eat dinner) it jumped to full. When I fired back up to finish, it went back to empty... /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif
Obviously a PROBLEM. /forums/images/graemlins/frown.gif /forums/images/graemlins/crazy.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif
I have the owners manual, shop manual, and parts manuals to this tractor, but haven't had a chance yet to get them out for a look-see.
Now here's where you come in.. Any one know how I go about checking (1) the sending unit? (2) the guage? Is that guage "fuse protected" in any way? I'll check the wiring between the sending unit and guage when I get home this afternoon. /forums/images/graemlins/tongue.gif
Anyone have any advice? /forums/images/graemlins/confused.gif
Thanks in advance! /forums/images/graemlins/grin.gif
Bill
   / Fuel guage troubles #2
Bill;
Check the wiring to the gauge as well. Don't overlook the ground on the sending unit. Easy check. Run a separate jumper lead fron the sender body to a known good ground.
To test the sender itself, out of the tank, connect ohm meter to the terminals, and slowly raise/lower the float. You should see a steady change in the resistance with no spikes to infinity. I'd be surprised if it is the sender. A bad spot in the sendinr resistor should correct itself as the fuel level goes down moving the wiper past the bad spot. My best guess is a bad ground. Most common problem.
Richard.
   / Fuel guage troubles #3
If you have other gauges that fluctuate, It's probably a bad ignition switch, (or especially if no other gauges).
   / Fuel guage troubles #4
Sure sounds like an intermittent ground problem which would explain why the bumping around makes it worse. Possibly only a loose ground connection, that is occasionally not grounding. If it were another wire, hot, you'd probably blow a fuse. So I'd go for checking the grounding first.
John
   / Fuel guage troubles #5
will 2nd KiotiJohn's theory. if not a bad ground, look for a partially broken wire, no telling how those wires are after many hours of use.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2007 Ford E350 (A55973)
2007 Ford E350...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
Metal Fisherman Parking Only Sign (A57454)
Metal Fisherman...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
